recreate the contour of a restraint
  • Thread starter Thread starter archilan
archilan
Hi, guys.
is my first message in this forum, so as I wish what I greet all of you:smile:
I tell you my problem
I have to model an urban environment (plan for now) as a base but I only have poorly designed lines and hatch but without their contour. I was wondering if with autocad 2008 you can create a solid from the hatch or just maybe regenerate the contour! so avoid to close all the lines....:eek:
thank you very much for the availability!
to the
You need to recreate the contour.
command editing -> option "recreate contours"
2008 I don't know if he does, 2010 certainly does.
Anyway, look around a lisp that recreates the hatch contour, now I'm on the way I can't find it.
Bye.
the command esite also on 2008!
I saved a good job! !
There are so many things I don't know!!
thanks again for the promptness!
to the
