Rectarular slig
  • Thread starter Thread starter robyf80
robyf80
Hello everyone, I would need help to create a rectangular section spring with nx-6..
I explain my problem:
I create a propeller with the size I need, I create the rectangular section with the centerpiece of this section lying on the end point of the propeller and use the sliding command along a guide to create the solid.
My problem is that I would like to avoid that the section, while following the guide path, rotated around its center: I need an external and internal cylindrical surface.
do you know if I'm wrong, or is there any option I have to select?
thanks in advance
Hello everyone
roberto
Hi, you're wrong. to do what you need to use the swept command with the settings as in the figure:
selection of the guide
Select the section
then you have to choose as a method of orientation the vector z (or what represents the axis of the spiral).
I hope I've been clear,
bye:
