redefine standard text in technical drawing paper
  • Thread starter Thread starter marroneant
marroneant
Hello, everyone!
I have a question to ask you. every time I have to make a technical drawing, I have to change all the words in the cartilage according to what I am working on, of course, but there is information that I never change as: company name, designer name and various titles.
how can I set these parameters as standard?
for example instead of reading designer set designers etc.
I could save some useful time every time.
Thank you so much!
If you want to make changes you want to always find when you create a part or a design, you have to make them in the template files of the "templates" folder, which is usually under the "inventor" installation folder. in your case you have to open the standard.idw file, edit the folder as you want, then save it. every time you create a new table, you will find the changes made to the model.
Thank you so much!
