reference seen "model"
  • Thread starter Thread starter supertramp
supertramp
Hello, everyone! I have a little problem that I couldn't solve by spraying the default custom.
every time I create a surface in a component of a set, this automatically goes into the reference set by default, the model.
There is a way not to link the surfaces to the reference set "model", how did it happen with older versions of nx?
It's a stupid thing though for my job I almost never need to create different reference sets and so often I only use the default reference set; only that I have to uncheck from the "model" every surface I create in the components not to mess up the axieme. a solution would create a new reference set and work with that and in this case this automatic association would not exist. But I noticed that when I take the assemblies in step, if I have created custom reference sets, these will be part of the component name in the axieme. (as I write bad would say napolitan crozza:)
for example, if I carry the assieme ring.prt in step (with command save as), the diamond component.prt if it has the reference set "silvio" will become diamond_silvio.xxx once reimposed in another cad. If you have the reference set "model" the customer will see the same names as I see and therefore I prefer not to change the reference set... I hope to have explained :wink:
in the attached image see which flag set to have a reference set with solids and surfaces, solids only or no automatism (as I do). for the export of the step I prefer to use the export command and not save by name.
I've missed the flag.
for the removal instead I use the save as only because the customer who opens the axieme made in this way sees in his cad the names of the components. If I used the export (which I prefer too) would see the components as solid1...n and without names it gets nervous because it is impossible to identify the parts without opening them and rename them.. . If you don't have the same problem, I think I'm wrong with classical export... :rolleyes:
