matfio
Hello, everyone.
I've got a little bit on the reference set that I've been carrying since nx6.
I try to explain.
I create a new reference set with name "model" I add an object. It's okay.
I add surfaces, solids continuously for various reasons and I find that the reference set "model" is full of objects. I try to uncheck them to have only the basic solid and give me as a result 1 selected entity.
apparently it is correct inside the component but when I go in the mode together I find that more than one object is displayed. What to do? cancel and recreate the reference set is not as correct as a procedure but I am forced because there is no way to settle.
I remember that previous versions (from nx5) had the following options: add objects, remove objects, edit objects and when I happened the problem of selection the only possibility I had to solve it was edit objects, select all, invert selection and finally select the desired object again.
I press that in the environment together there are saying methods to view the interested object but I am a free professional and I must always adapt to the ways and methods of working of my customers.
Can someone explain to me if there's a solution for version nx6 onwards?
I try to explain.
