region of repetition
  • Thread starter Thread starter nino67
nino67
Hello everyone,
the formats that I use in the company for drawing boards carry the repeating region table, such table guides the separate bubbles.
it happens to have to replace the format, *.frm file, in the drawing to update it to the last version or to change the format as size, the technique I use not to lose the bubble consists in not removing the region table of repetition while replacing the format. this makes the bubbles remain in place but any changes in the table itself should be applied by hand to the table present in the drawing, for example column width, text style, parameters etc. etc.
My question is:
Is there a technique to clear bubbles from a repetition region and hook them to another?
ciao,
I don't think that's possible.
However, you could insert a format that does not contain the table, so you could change the cartilage at will without uncombusting the repetition region and related bubbles.
I suggest you make the format independent from the tables.
Thanks for the tips, I was afraid it wasn't possible.
at the end the fact that the repetition region is either in the format or not is not a big problem as during format replacement it is possible to choose which tables to maintain and which to remove. remains the "cut" to update the table by hand for any changes in style or parameters displayed, otherwise just accept the new table and lose the bubble.
really a big peeling (without quotes), it would bother me very much not to be able to change the format to a design for the risk of losing all the bubbles of a complex set, maybe moved by hand and arranged with patience in a very precise order.
Undelete the table from the format and the problem is solved, or replace the format while keeping the tables.
aminati
aminati
thanks to all for the advice, always useful and punctual but....
.... the techniques to avoid this and that I know you, my main question was and remains the following:
Is there a way to change the region of repetition without losing bubbles?
Unfortunately I fear that it is not possible ......, as an amateur programmer I think it is not difficult to implement such a function, convenient when the repetition region is "heavy" magazine for sile and parameters displayed.
