reinstallation of revit
  • Thread starter Thread starter Erikilrosso
Erikilrosso
archaic question: I have to reinstall revit from the 2012 suite but I don't remember in which, of the dozens of folders, I find that of the revit set-up. I felt that the installation left alone and that, inserted the pass, then you could proceed to install the programs contained in the key according to need-
Maybe gfrank or tristam can help me.
Hi tristan,
I was convinced that he left alone. in the root I found in x64>program files>root I did not find .exe files. opening the wrench I find a setup file that only contains a revit.dll and a res setup file that contains images.
I want to try to reinstall it because it distorts the colors when amount images, it also distorts the colors of its renders.
I'm a little in crisis.
not having an old usb key under my hand I struggle to help you. ..however, not in x64 > program files but in the very first folder inside the key
hi tristan, after the last messages I stayed out of service for some time for personal reasons, in the meantime the problem that I had submitted to you has not resolved and the last works with revit I did them as I could, exporting the boards in b.n. now the problem is complicated since I wanted to pass from win 7 to win 10 and after the installation of system I could open once revit (in French ..) and then never more, as much. I tried to install the suite 2012, but at the complete conclusion of the revit operations it is not installed. as I can't remove it because it looks, the same file is missing.
Now I have a couple more jobs to finish then I will close my p.i. and I will retire, but I'm afraid to go around asking a colleague if he lends me his revit to complete an assignment! !
Basically: I would like to remove revit 2012 with its outbuildings and reinstall at least the 2012 suite to close in glory! But how do I do it? create a new partition on the disk and install there revit? and what I have left in the other thing? Do I have to format everything?
thanks tristan I have uninstalled without problems and now I try to reinstall it. I'll let you know. Thanks again
nothing to do: the installation procedure takes place regularly but in the end revit is not installed continuous to try, you never know. However perhaps, my 2012 is not configured for win 10.
I'll see if I have a partition on my drive to install win7 and revit. hoping it's feasible and not to mess up.
