remote computing seen
  • Thread starter Thread starter chipier
chipier
since I installed the 18.1 when I remotely calculate the views does not calculate the threaded holes.
Can anyone help me?
the only reasons I come to mind for which the threaded holes are not "calculated" are both due to the properties of sight:
- do not have the flag in thread lines in the visibility menu
- have put in the filters a diameter of the circles full greater than the diameter of your threaded holes.Proprietà filettatura.webpI still have version 17 and I never used modeling in "remoto"
I apologize for bringing this discussion up, but when you answer at the time you probably misunderstand the sense of the question, that is, here I think you talk about the remote update of annotation views, that is a function that allows you to upgrade to another pc, remotely connected, the view, while at the same time the designer can move to 3d environment and continue to work without staring to see the green colored update bar.
what I ask myself is whether this possibility covers a license also on the computer remotely and if it can be used satisfactorily even with pcs connected to the external network (i.e. when I am in the office I update the home pc and vice versa) or it only makes sense to pc connected to a company network.
