removal constraints
  • Thread starter Thread starter Rikimaru
Rikimaru
Hello, I would need help on removing constraints in revit 2012.
I created a solid and used the "alline" command to align the edges to a reference plane or to the end of another solid. I bound the sides on the floor closing the lock that appears to me after running the command line. But now I need to remove some constraints to this solid only that when selecting the object I no longer see the locks to be opened to eliminate the constraints. How can I do that?
thanks in advance for availability.
the command aligns for your object on the same floor as it is already paddling, should reappear the lock that at this point you can open. . .
If I'm not denied... :rolleyes:
I tried to do as you told me, trying to align a second time. The lock already appears open to me, and it is as if it were a second alignment. the previous bond remains closed. :frown:
Maybe I'm wrong.
Could you not try to delete the object and then recreate it by giving it only the necessary constraints?
recreating it or giving the brutal removal of constraints seem to me the best methods.
Thank you very much for your help! :
