remove custom properties from multiple files
  • Thread starter Thread starter Tantocattivo
Tantocattivo
Hello everyone,
as from title I should remove all custom properties from many files, and I would like to use something automatic.
on the internet I looked for the text of the discussion and found nothing except a non-functioning macro.
I wanted to try to make a macro and use planning utility, but I doubt that there is a way to automatically select all properties. Maybe if you just don't know the solution, suggest me some research term.
Hello, I am trying now, but cmq in the meantime thank you so much!!! ^
the macro works, but it deletes the custom properties and not those that are in the specific configuration tab. I also have configurations in parts with their properties!! can you change easily?
In fact!
from how you wrote me I understood only the custom properties, not the specific configuration.
So you want to erase both custom and configuration ones?
of all configurations present in the part or only of the active one?
give me confirmation
In fact!
Yes, yes, I have to delete everything, in all configurations, active not active.
it works great, thank you so much!!!! is very useful when for example when downloading files from the internet that have 2000 properties for you useless! !
View attachment 43774 but where do you tell the task scheduler to run the macro on all parts and assemblies? if I choose other operations it makes me choose files, folders, parts or assemblies, but if I use custom operations I don't see anything!
Yes, attached in the previous post there is the image of that screen, I choose the macro but there is not the part that tells you where to apply the macro (parts, assembling folders), as instead if you choose for example export files or print.
Thank you, I was reading it right now!!! ^_^ I had to search on google.com in English because in Italian I found nothing!
Try this, it should be your case.
Let me know.
jenuary
Good morning jenuary,
I would like if it is possible the same macro but that cancels the extension of configurations leaving those customized
Thank you very much in advance
Staff online
