remove dependencies from copied feature
  • Thread starter Thread starter Shotfree
Shotfree
Hello, as from object I need to remove dependencies between two features copied in one part. in the old versions of I create the operation was feasible through a special menu that allowed the removal of the links defined during the copying of the feature, currently I use I create 5 and I cannot find the option that dissolves this link. Thank you all for your help.
good morning to all, found solution, the public to the advantage of those who after me will be faced with the same condition:
situation: one or more processing was generated by copy and maintained (by choice) dependencies from the first (foro2 has the diameter dependent on hole1, then changing the first one changes the second:
I redefine the hole2 (the one dependent on the hole1 to understand us):
vary the diameter and click on confirmation, at this point I create it tells me that the hole was dependent and that from now on it will not be:
