remove participant from working on together.
leggera
Good morning.
It is already the second time I happen and after a working of digging on a set I must renounce the parts that are not interested in that processing, but it allows me to do only 1 part at a time.
They usually select a bit and remove.
I don't understand why you don't let me do this together. . .
Is there any tricks?
hold down the ctrl key to make a multi selection?
edit:
a make-up can be to isolate only the interested parties to the processing (by cutting from the visibilty the uninterested parts) perform processing and make it visible all.
inventor interprets only the parts at that moment visible as working participants, or possibly with add or remove participants.
Yes multi selection I was doing it.
only that of 10 parts I remove 1 only.
I try with that trick you suggested.
