rename blocks according to file name
  • Thread starter Thread starter Raffa1736
Raffa1736
Hello, everyone.
My name is raffaele, I'm a professional unlibero. for work I prepared a file of autocad, which contains a large amount of blocks. This file would be (yet it is not for the problem that I am putting here) very useful in design, if I could rename the blocks according to how of the file.
I'll explain. I have a file called disa, and the blocks contained in it are, for example:
disa_b1
_
disa_b12
disa_k35
now I would like to make sure that the first part of the block name is the file name (dise); so that if except with another name, for example, disk, automatically the definitions of the blocks become:
disc_b1
_
Is it possible for you?
it is not possible,
first you need to rename the blocks and then save with new name
it is not possible,
Unfortunately the blocks are dozens. If I can't find an automatic method of doing this, I'll have to leave the speech.
command: saveasandchgblockname
1) enter the new file name, without extension
2) all blocks containing the character _ are renamed
3) saves the file in the same directory as the source file.
bye
bye
!!!!!!!!! Thank you.
I was sure you could do it. I had no idea how to do it.
You really did me a big favor.
Thank you, raffaele
