rename drop-down menus
  • Thread starter Thread starter stef_design
stef_design
I know, the question will be strange to many of you but I do the same to you.:eek:
Can you customize the writings of the drop-down menus?
for example change the file writing, edit view, etc... and also the underlying items?
test with dx key on the bar or view/bar of the tools.
from them you should be able to do everything.... try then let you know (I never tried)
should work even if only for the contents of menus e.g. open ..... etc. etc. etc. etc.
tried............ works for commands and menus, not for menu titles to pop up file type, edit etc. etc. but for the internal commands you open etc. ............ if I find I say how to do also for those:biggrin:
Thanks mcbramby, but I intend to change the name that appears above the command. as in the image
always in commands you can change even those that then comes out as info..... modifying "title" .......:biggrin:
But your isometric view I didn't find it ....................................................................................................................................................................................................................................................................................
when you walk with the mouse pointer over a command appears the command name. Here, I would like to change the name that appears. example: pocket, fitting, open, material...etc.
Can you do that? ! ?
from what I have seen you can only change the name of the commands of the drop-down menus but not the name of the commands in the bars.
but in this way you buy your life. to every new version you will have to adapt the menus!!!
quoto falonef :confused: ............... cmq in customization if you change the "title" in the commands you change what you see through the mouse.
I don't know how many and what commands you need but you have to look for it here.
Try to do some tests, I tried with the "open" command and it works:smile:
Good morning, everyone.
I would like to know if you can add a new drop-down menu (maybe after driving ).
If it is not possible what is said, it is possible by customization, to create a new bar with the icon opening other under icons, like those of the views, to understand?
I wonder if I can help because I created fifty macros and assigned them to icons. Unfortunately, many people occupy me a lot of space. I thank all those who will help me. Thank you.
