rename files together
  • Thread starter Thread starter Toty94
Toty94
Hello, everyone.
I use inventor for a while but today I have a doubt. I created a file together, drawing, presentation, rendering image and video rendering.. .
But now I would like to change the name to the file together without losing any connection. Can you tell me how? for parts I have always used design assistant but for assembly files?
Thank you very much
If you do not use vault, you must manage everything with design assistant
find it in windows start, autodesk, design assistant
_foto__013.webpyou have to launch the program and select the table set file (dwg or idw)
the program shows you the content and then through the action column you can rename or duplicate an entire together with its 2d tables_foto__014.webp
