rename "number part"
  • Thread starter Thread starter realone
realone
Hello everyone!
I am new to the forum so take patience.
after using the command "generates numbering" the program assigns to each part of my product a number. can I somehow replace the "number part" with this number coming from the automatic numbering?
go to instruments/options/mecanichal design/drafting/ annotations and detailing
and put where there is the "numeration" ball:wink:
Maybe I couldn't but explain myself well... in reality what I would like to succeed in rename is the name of the part inside the tree
then if I understood (because it's not that it's clear) you would like to put the number of the ball in
the name of the part????? Do I understand?? otherwise put an example............ :confused:
I have never made any evidence about it but I think we can only do it by creating a macro .................... You could hear the software house that provided you with a casket and ask them if they have a chance to do it, even if I don't understand the utility.......... :confused:
in the panel that tells you to mcbramby you just have to choose "part name" and you check the number to the side file.
if the problem is to assign the name to all parts of the axieme with management rescue checks with matrix the automatic numbering of the part.
However, from my point of view, it seems too complex to develop a project.
hello to all you know can rename the part number or be able to assign them by hand without making them do it automatically?
no, it is not possible
If you need the ball in the catdrawing, you can do it manually.
