rename part and axioms
  • Thread starter Thread starter gil
Please note that you pay the license also for the vault and do not use it.
a technician in a day installs, creates the environment and makes you training, so an all-in-one cost accessible.
if you have a capable computer in the company can do it quietly.
other important thing, if you are multiple designers with the vault you avoid messing up type file modifications to the unknowing of others, especially on parts that go into multiple assemblies.
I choke the vault. in addition to rename files and recreate links, files can also be moved to folder with the same result (no link loss and archive reorder) and also has other functions that I am not now saying but are useful (e.g. project copy). this is worth both team and if you work alone.
for tarkus: install the vault and start using it that you already have it and you just have to configure it.
the phrase on reopening the assemblies if you renounce with design assistant refers that you open the first set and do things for good and all about that axieme works, but if you have another set that contains the same ex-files, at its opening you no longer find them you have to make them go back by hand.
................ for tarkus: install the vault and start using it that you already have it and you just have to configure it.
So you confirm that you reassociate renamed files?
I confirm everything 100%. and I add that when you rename a file you have the possibility or not to update the part number for the distinct.
use it and you will see that (as with each product) you just need to understand the mechanism. Then you won't let go.
After doing many tests to copy and replace files part and together, I would say that there is no doubt, vault obviously remains the best solution, while in other cases "design assistant" taxally.
for drw's associative speech to their prts, if you forget the drawing associated with the old part that has been duplicated with a new name, no panic, do the copy and paste of the drw and then under "manage" you use "replace model reference".
. do not miss anything because the references are always the same, both with the quotas recovered from the model and with the manual ones, just tried and everything perfect. autodesk hardly makes caxxate like ptc, dss and siemens...
The odds are not lost.
If the file of origin is the same, do not lose anything, but if you have made changes before you associate them, lose them, lose them,
as when the replaced file is different .. miracles does no one ...
and you make changes later, or not?
you can't always manage workflows like tea..
I however before making changes I reassociate the new table and in the assieme I make a "save and replace component" so I do not lose constraints and leave from a clean situation. I'll change the file and if something doesn't come back, I'll fix it.
then everyone is free to act as he wants.
