rename solids
MARCOC
hi to all, here on the forum and also on internals I found several holograms to automatically rename the bodies, but no I find anything to rename the solids, I place an image for clarity1618652526419.webpDoes anyone know if possible, do I have something already? ? ?
I would need to rename the solid so
file name: pippo.ipt
bodies : pippo-001 eccc
solids : pippo_001 eccc
they differ only for the hyphen, because obviously inventor does not let you do it as it finds 2 equal names
Thank you very much
hi, we had already made some discussions about it, see if this can do to your case
Good job
Good morning.
I'm back on this. I press that my programming knowledge is zero.
thanks to matteo hats I had downloaded the rule that I carry below:
syntaxeditor code snippetdim sb as surfacebody
dim doc as partdocument = thisdoc.document
dim sbs as surfacebodies = doc.componentdefinition.surfacebodies
dim sbname as string = thisdoc.filename(false)
dim suffix as integer = 1
' loop through all solid bodies, renaming them
for each sb in sbs
sb.name = sbname + "_item_" & cstr(suffix).padleft _
(len(cstr(doc.componentdefinition.surfacebodies.count)), 0)
suffix + 1
next
this rule when I execute it renames the various solids of the multibody part by applying the "filename" and adding as item_x+1 suffix. very useful.
Now I have another need. I would like to rename solids not with the nomdelfile but with the "description of the work" generating its solid. For example, I would like the first solid to be called "structural memory13". allego screenshot explanatory.
Is it feasible? If yes, how should I change the above rule?
probably the solution has already been posted but not chewing much what I am asking for more explicit support.
I thank everyone who wants to help me (ps.... all comes from a step of a customer)Screenshot_1.png
