render con rhino
  • Thread starter Thread starter ZIOCLOD
ZIOCLOD
I would like to know if with rhino you can make pictures of us through the vray application or others but of photographic quality and where you can possibly see files rendered.
because it is explained by the fact that my client needs to make photos of some products gave me the files that with c4d I can not open correctly, while with rhino you. so it was my intention to know more about these renders and conversions of files. and honor of the truth, check with you what is the best program to make photographers. If I have to learn how it works, it is worth opting for the best. I already made a mistake with c4d and I would no longer repeat it. great prg but bad use of customer files and it is not my intention to remodel objects.
hi I had similar problems, see my previous discussion. . I wanted to go to rhino for reasons of making and alternative to solidworks..posso tell you that exporting to vrml 97 I had good results. .
c4d is usually very efficient in opening files. sure if they send you a solidworks file doesn't open it directly.. .unless you have the version engineering. if you already have the license of the base I don't think you'll have trouble converting it with the eng, paying the difference.
I tried now to convert it to vrml and not 97 as in rhino does not appear to me. A kick. curved surfaces are sliced. Not good. to refer to c4d engineering I saw that it opens stp files, as they delivered me, but before buying it as I can know if it does to my case. I don't trust me anymore: first touch, then pay! (as that joke said). that you know I can turn to someone to make me do this test or better if I can download a demo version also that you do not save, so much to verify its goodness.
I don't know, ask retailers. I told you about c4d and. because you already have it, but obviously there are also a series of rendering plugins also for rhino, check the cost if ever, what you want.
there is brazil, vray, maxwell render, fryrender and arion (make interactive via gpu, very fast), flamingo, which are those who work the file inside rhino.
but sorry now that I think about it, you care about the step in rhino, then you have to export to c4d? I from rhino to c4d port in dwg or dxf, setting export options, (max number of polygons) files are perfect, with all layers in place, where is the problem?
Now I try to export to dwg or dxf, then I know you. I think I can't do anything else today.
try to set in export preferences the best solution, I do not have rhino now underhand, if ever place.
export the maximum number of polygons, and don't worry if you see faceted in c4d, the important thing is that in making it all smooth, the smooth is automatic, as long as there are no few polygons. there is also in the preferences c4d settaggio dxf/dwg.
enri, I tried to export to dwg and dxf in dwg I gave value 500 to polygons and was opened in c4d as if it were in rhino: quadrilateral polygons and no flaws. But it doesn't make me the render. Maybe it will be that they are not closed polygons or anything but the rendering turns out black and the computer makes a struggle that I don't tell you to move everything. I think if I don't solve this, I'll take the file key and I'll take it to the river next to the studio. I don't want to be intrusive, but if you like, I'd send you a detail of the original file and tell me what to do.
Anyway, thank you.
c4d is usually very fast to manage the scene, at least with ati, post the 3dm file if you can, I will see what I can do.
