marinji
Bye!
revit use 2013 (student version).
I would like to make a render with a single material (white) applied to the whole model without having to change each individual item.
I tried to create a filter of the stages in which everything (new, existing, demolished and temporary) is replaced with a single material.
the fact is that I would like to keep the glass transparent.
so I put the windows and the facades with the glasses in another phase compared to the whole model, which in the filter is not replaced.
the problem is that in the continuous facades remain of their original material also the unglazed panels, as I can not manage the phases of the single panel but only of the whole facade.
How can I get a similar result? https://www.kenji.it/rendering_treviso/rendering_volumetrici_2.jpg (image taken as an example)
Thank you in advance! :
