render edges
  • Thread starter Thread starter frencisis
frencisis
hello to all I immediately expose you my problem:
I made a 3d with autocad 2009 but since the rendering of this nn I like I opened the .dwg file in 3ds max design 2009. At this point I applied the materials and I made only that as you well know the edges between the various faces are not visible 1 time rendered: x explain me better I would like to make the rendering having the evigenziati edges of all figures as it is possible to make x example in solid edge... is there a way to activate them? If you could explain it in detail since I'm new?
with the materials "arch & design" you can do, although I did not understand if you can set a custom color.
into the material, in special effects active active round corners and impose the thickness of the edge. theoretically you could also set a color or a map but I couldn't
