render transparencies
  • Thread starter Thread starter deba7171
deba7171
I applied an object fade using visibility from 1 to 0 in 5 sec. but in the rendering phase the object remains solid until 5 sec. and then disappears of barrel. depends on the type of lighting, the material, or any object?
tanks
only in viewport or even in rendering? because in viewport may only be a visual "feedback" of what happens, but then in rendering could be correct.
If this is not the case, how did you step up the animation of transparency?
the transparency animation is in line with your indications but I just saw that the material is the key point.
in viewport is visible the switching off by fade, but in rendering no.
I did a test by replacing the materials to dissolve and replaced my generics the architectural type. But now I don't know if it was enough to set something to the generals. I am not a great expert on materials and their parameters,... I will have to engage...:smile:
I used the automatic keys but aspiring the new color and not changing the animation the effect managed.
As soon as I have a minute I place the two materials.
