rendering con thinkdesign
  • Thread starter Thread starter Simold
Simold
Greetings to all.
I have the need to create a series of "decent" images, this is the adjective used by the boss, by cad models.
It's the first time I've been doing something like this and I've been using td for a while.
My tyrant traverses started with gbg and then went to proe.
now new employment and new sw.
However, what I attach is a test obtained so far by handing out with the library rendering of td 2009.3
I asked you if it was possible to intensify the transparency of only objects in green.
I accept any advice to improve the whole and obviously any criticism for the one that has been obtained here.
But have mercy, believe that, when I go luxury, I must fight only against a cold, freezing and insensitive 1.2344.
Therefore,with the going of time,I had to ignore elegance and move to strong manors.
ciao,
thinkdesign uses http://www.lightworkdesign.com/ as a rendering engine, so you can browse the site for additional images or information.
here I also bring you the blog http://blog.lightworkdesign.com/ You never know.
Another important thing is to have rendering bases in general, and to touch as little as possible the various settings, if not you lose the compass .. maybe it works more 'with light than with materials .., and keep in mind that then a repass with gimp always helps :)
if you don't pull your feet, export everything to stl (multifile option), upload the file to blender .. and make them ..
Matteo
ciao,
Matteo
firstly thank you for the attention.
I start by throwing an eye on the site you indicated me and hope to find some interesting point.
I agree in full with the speech of having a basic minimum in general!!
It's been a while since every request the boss concludes the surgery with "how long do you want? "
hello and good day.
