rendering edilizio
  • Thread starter Thread starter tonygancio
tonygancio
good evening to all, I'm trying in a pretty complex rendering I think...at least x me...usually I use showcase x small renderings of interior, it's time I would like to use 3d studio.
the file is already texturized but I think the textures have low resolution and I don't get a good result.
I press that I do not know the program but being the scene already "ready" I wanted to try.
What can I do? Can someone help me if I turn the file?
Hey, can we give you some advice, because if we do the job, but you take the money, you explain the meaning of this? but then why do you start using 3d studio max on a difficult job? Was it not better to use still showcase and start on 3ds with something simple?
3ds is not like showcase; there are dozens of settings for rendering that you do not learn in a handful of minutes.
I then fully share the thought of lattu. starts with an easy example and if you are not able to do a job lets you do to those who are more competent.
what I'm trying to do is not for work, my job is something else but I like to make rendering...it's true that I took a difficult example, as I said I decided to try with 3d studio only because the scene is already set and that's all.
with showcase instead doesn't take the textures already applied and I don't understand why. .
I will change subject and begin to understand the fundamentals of 3d study.. .
hi, if you want a hand start by posting a rendering, so we can help you, but 3dstudio is a very complex program and you do not learn in a few days or without doing a course (which I highly recommend) :finger:
