Are you using presets? if what (medium, draft, high...)?I need some advice to improve the bad quality of my interior renderings...even by putting some internal lights...it turns out very dark... Here you are the result! ! ! ! !
after you've done all your tests I recommend the autodesk 360 rendering inscription, you'll be able to make your works by autodesk in a tenth of the time you'd take:I need some advice to improve the bad quality of my interior renderings...even by putting some internal lights...it turns out very dark... Here you are the result! ! ! ! !
I made the render and it was 15 minutesafter you've done all your tests I recommend the autodesk 360 rendering inscription, you'll be able to make your works by autodesk in a tenth of the time you'd take:
I'll give you my proof today.
the time of 9 sec. is reported to the reprocessing after I had modified the exposure values to end render, however it had not employed + of 30 min in excellent quality for an image to 2000x1400 pixels
depends on what pc you haveWhat do you say? we accept advice... .
the pc took 10 hours... Is it normal?
thanks cristina
the ceiling still has boils, need more rebounds of light0000000000000000000000000
