rendering of the product
  • Thread starter Thread starter alex369
alex369
Hello.
after applying the "section" command, if I try to render the product the section cancels. How can I solve this? Is it possible to make a single pocket for the whole product?
I tried to do the section, then in definition/volume cut/ok, the details remain dissected and applying the shading with material, you see rendered. . .
However if you want you can make a pocket that involves all the product, only that then really cuts it!!! Is that what you want?
Let me know.
Yes, the problem is that if I go to make the surrender I recompile the whole model.. .
Let me know.
I am always the user with the pocket problem, in fact if this thing succeeds would be a miracle (the pocket on all the product)!
Now I answer your question, but first I want to ask you: what do you have to do exactly by doing the section? do you want to show the inside of the axieme?, it's just for the graphics (see that you want to render) or do you actually need to cut a set of parts? Can't you do it in drawing?
normally the dynamic section is aimed at the analysis of the inside of parts, so it is only graphic and very fast, while the cut or pocket in the product is not.
do not expect miraculous solutions that cut all parts in one shot only, the system will ask you to select the parts you want to cut and in cases like yours, where in one part you have more body and surfaces, the system will cut only what at that time is active, so every time you will have to activate in the part the object to cut and repeat the operation. . .
then in assembly design, load the parts into the product, and create a part with the cutting profile (a surface but could also be a simple plan), then from the menu/i insert/features of assembly, use or size or pocket.
the system will ask you to select the surface or the cutting plane and will open a window where all the components are visible, you select and move those you want to cut into the field interested parties, select the side and the ok...
You can see that where you have multibody in one part, the system can't make you choose the affected part, it only cuts in the active part.
careful that working in the context of a set, it is dangerous if you are not experienced, maybe at a time distance change the convinced cut to apply the change to a single detail, but ahimè he also cuts you the others you forgot about.
I hope that's enough.
