Antonio Penna
Hello, everyone. I would like some advice from someone who has already dealt with the following problem: the renovation of a brick building of two floors and attic previews the reduction of the height of the ceiling of the attic in order to make usable (at least until the point that the ground is at 2.70m) also the latter. I now represented the whole building as a "actual state" and should represent the "project state" with the lowering of the loft. the roads I have assumed are two:
1) demolish all the walls of the first floor and the attic with its floors and then put them back again creating them as "project phase" with the new heights;
2) leave all the walls as they are and create only the new quota to which to correspond the new loft (the old must however pass to "demolito"). procedure, this, which is consistent with what will happen in the construction practice but which in revit leaves the old walls (higher) that emerge from the lowered loft.
can any suggestions on the most correct road to take? Thank you all.
