carlo bondi
Good morning my name is carlo bondi and I am a mechanical detailer.
I mainly deal with table and explosions, and a little design mainly of conveyor belts.
I am addressing you because despite using the software inventor for about 4/5 years, I do not know how to copy an ipn presentation file, and once I create a new code, replace the original axieme, as can be done in the tables (idw) in resource management.
I found an article on this forum that contained the same request, which they replied to use the autodesk application: harsh design, without clearly explaining the steps to be taken.
There is a luminaire among you that can answer me, in an exhaustive way, even with a dry no one can not do, but in case you could use the application, in the correct way, thank you very much.
