Replacement design styles
  • Thread starter Thread starter essebi
essebi
working for several customers, I often have similar components already designed for a customer to be able to reuse in the design of another customer. clearly the duplicate project file function present in the vault is of help, however the table setting is however remade because the styles of a customer can also be very different from those of another, so the views are updated but the odds and annotations remain with the original characters and sizes. updating styles does not work because each customer calls styles in his own way. I was wondering if there are any macros or methods to completely replace quota styles, without having to delete everything and remake. or if I want to take the handbook on the bees and write one of macros... thank you all, hello
If I have not understood bad the question you can still select the quotas and from the annotation menu > format choose the new style of quotas... with a selection filter you can take all odds at once. Also there is an add-in that automatically updates sketch symbols, carts and edges at the opening of an idw referring to a template file to "fish them"... was the answer you wanted or understood whistles for whistles?
Bye!
thank you, indeed yes, you have centered, I have caught whistles for whistles >:-( and I have not even noticed the functionality you mentioned. . .
I took a year before I realized that there was for quotas; another year before finding it also for the material list!! :tongue:
