replacement hole sketch.
  • Thread starter Thread starter Alex_87
Alex_87
Hello everyone, I have been wondering for a long time: Is there a possibility to replace the sketch of a hole with a created by me? in practice when using the hole command, the sketch is placed on the point where I clicked with the mouse and at that point position the axes. to place the axle sisity I have to resort to a boring path, that is right button on the sketch > object sketch > changes the reference of the sketch. from here I can place it as I want. if I create a sketch aside (without links to the created hole) and try to replace the sketch (dx button on sketch> replace.) of the hole with the created one comes out the ban symbol instead of the pointer. Is the operation or the command not valid for this type of replacement? Thank you very much in advance.
You probably can't do it. a curiosity: why should you replace the sketcher of a hole?it is no easier to create a sketcher of support, containing 1st more points, and at the time to create a hole you select as first one of these points? I usually do that. if you then need to move the hole, just change the support losketcher
thanks robcrac for the answer. I'm also using the same method you just said, that is to create the support sketcher. the problem is the change of the position of the holes because you have to look for the sketcher of reference. then in the modification of the sketcher, the part becomes red and you can not take points or lines of reference. I think it's a method that doesn't use everyone, so in case a colleague would be in front of a file like this, it would take a minimum 15min to understand the method used.
