replacement of a part together
  • Thread starter Thread starter Brethil
Brethil
Good evening to all,
I find myself struggling with a dilemma that I don't know how to solve without putting a century to remake together and put into the table. .
So, I find myself with this "pippo.iam" in which there is a set of almost rectangular plant machinery; Now, I'm having to replace the sheet part that forms the bottom (which I'll call "fondo.ipt") with a new bottom always in sheet, but bombed. .
The dilemma... if my new fund was constituted by a set (fondonew.iam) how could I replace it with the old one that instead was a *ipt file ("fondo.ipt") keeping the constraints with all the above parts?
I say this because my terror is that; assuming that I can replace the old bottom with the new without creating problems to all the constraints of the above parts, I do not want to have to undergo the complete modification of the carpentry table that was already beautiful and finished, ready to print...sigh!
Any advice?
thanks in advance
transform bottom.ipt at bottom.iam simply creating a lowering level
at this point replace a .iam file with another .iam
clearly if the forms are very different.... the constraints will jump
open the axieme, select one or more parts, dx key, component command, lower level; you will be asked to give the name to the new set, the destination folder and the Templete file to use (usually standar.iam)
Yes, but to say that you are turning a part together is not correct (also because it is impossible to do). you are inserting the part into a new set created, lowering it level.
