replacement
  • Thread starter Thread starter valeria_emme
valeria_emme
Hi, I would like to know if it is possible to replace orientation axes, I do not mean to rotate the piece, but to reverse the order of axes.
motivation: I must import the piece into another software in which it is important to consider the force of gravity, and if I roote it and save it, when the amount I still visualize the original orientation of the axes.
hi don't know if you can do what you ask, but you may ovviate importing the file you saved (the import result to understand us) into a new side file or together and use the positioning constraints to put it with the desired orientation.
Hello valeria, welcome back.
qui find the solution to what you are looking for, the soliduser post has the solution. :smile:
