rescue error: "impossible to continue to save"
  • Thread starter Thread starter Novembrine Waltz
Novembrine Waltz
Hello, everyone. I've had this problem for a while.
I'm working in 3d and after a while I quit (and maybe I can't save) buying this cute mistake that closes everything to me and doesn't even go the "salvation of luck", says something like that doesn't exist (incertainly after some time I gave it up to recover the rescue and I always restarted from where there was the last real rescue).
a girl told me that if I was working on the pen (i.e. leaving the file in the pen) it was obvious that it happened so. I had to put it on the computer and work from there and then put the file back on the usb pen.
He had, so I did, but nothing changes.
suggestions? ?
(other than learning more serious programs, but I don't have material time right now)
Thank you!
I'm sorry, but I don't understand.
If I have to make a 3d every tot of time I have to save him new with a random name? and if I just in those 3 minutes that I don't save get the mistake and closes everything?
to me it happened sometimes at the time of rescue o at the time of automatic rescue, I solved the way I described it.
if you don't even allow this copy all the content in a new dwg and save it.
"if you work on the "pippo" file and save it as "pippo1" it is always better to rename it later than remake the drawing from the last save. " [Massimo Catalano]
to me it happens almost habitually working in 3d. but not only on the same file, but on all.
and I have also tried to copy the content and copy it in a new dwg, but after a while the error appears again.
and I still don't understand your theory.
I'm working on a file called 1. after 5 minutes I work "save by name" and I call it 2. after another 5 minutes I'll do it again and call it 3. After another 5 minutes I'll do it again and call it 4. Then they spend 4 minutes and tells me " error, impossible to keep saving" and it closes everything. so I have 4 rows of rescue at a distance of 5 minutes from each other. I think and I hope I've got it wrong.
2011
it seems to me (but I'm not sure, I should try) that on the laptop does not happen, but that it only does it on the fixed
I mean? (and why in the laptop should be installed and on the fixed no if I have been myself to have installed the program from both sides? )
because when you install it asks you if you want to put the service packs and just say yes once and no the other, without paying attention to what the setup says.
or because on a pc you have the active internet connection and on the other no, so the sp. can not download them from the site.
Bye.
Since it only happens on the fixed, it begins to list the features such as: video card, ram, cpu, operating system (x64 or x86).
bye
beautiful question xd
However if it can be of help, before formatting it did not even happen on the fixed. Maybe I installed it wrong.
