MikLikeDrugs
Good morning.
I'm back here asking for help. I am in the design phase of a pneumatic cylinder, I have just been given the application (extremely spannometric and superficial): This is a cylinder that will raise a bar hinged at one end (lg. 5000mm weight 320kg). the assembly previews that you create a lever of third genus; what I care about is how to calculate the minimum f force to raise the bar; My problem is that I don't know how to "convert" the weight of the bar (I imagined you can see it as a distributed load) in a force at the end of the bounce.
allego pdf.
I also found this thread (https://www.cad3d.it/forum1/threads/come-calcolare-questo-cinematismo.20684) but I didn't get the same.
allego pdf.
