resolution output rendering and image printing reports
  • Thread starter Thread starter fpaolelli
fpaolelli
Hello, everyone!
I have to insert some pictures rendered in panels on boards now my problem is twofold:
- First of all to the act of rendering imposed the output file format tif or jpeg and imposed the resolution but what I can not set are the dpi that sets by default to 150 that in the printing phase are a little few and I would not want to shun the image.
-according to what I have to get these images in boxes 11,20 x 11,60 cm now I have two ways:
1 I choose an adequate resolution in pixels to get a final image like the pane, but I can't do it because you have to convert pixels in cm and making calculation the image is not scaled properly.
2 I could save in the right side ratio and then scale everything but now I wonder:
exists in autocad a function that allows me to scale an image of the exact size of a pane? Thank you and excuse me!
then dpi (points per inch) are linked to the size of the print you have to get.
If you need to print an image of 10cm*10cm that has a resolution of 300 dpi (on the card to understand us) the output from autocad must be a render with 1181*1181 pixels.
to calculate this you have to do 10cm/2.54 * 300 dpi=1181 pixer
vice versa if you want to know what print size has a certain output from autocad.. 2.54*1181/300=....cm
said this, and returning to the image size problem you can at any time resize an image, or crop it.
also with scale with reference steps from one size to another note. Obviously in this case the sides must maintain the same relationship between the starting size and your pane.
......-according to what I have to get these images in boxes 11,20 x 11,60 cm now I have two ways:
use the search function:
http://www.cad3d.it/forum1/showthread.php?t=15639
