results
  • Thread starter Thread starter zippovito
zippovito
hello to all I would need a clarification regarding the results in rhinestone
I am analyzing the stresses on a frame subject to wind and snow loads (as well as its own weight)
among the various options in the results card to the stress card missing in the list the voltage of von mises, are listed the various sigma and tau, I could combine them with the square root formula ....
but why not provide it?? ? ? ? ?
or, can you enter the formula in order to make it compute to the software, and have the graphical trend?
from the tabulation of the results I pulled out the values I could use them in a table of excel and do the rest, but that I work!! ! !
thanks in advance
p.s. one of the voices that proposes rhinestone for stress is total fibers that, however, is not complete!!
I've noticed this weirdness too, but I've never deepened. . .
I assume you created your structure with beam elements then. If you use plate elements (which are much more complex and sometimes useless) you should find yourself with the possibility to display the von mises.
bye
but modeling a structure with plate elements there is to shoot!! ! !
is it possible that there is no possibility of inserting a function?
