MBORGONOVO
someone knows if there is a way to create a reticular extrusion in wf5
in one command, without making an improposable sketch. . or a work-around.. .
given a certain area with delimited profile (of varying shape) I must create to its
inside a cross-line lattice that create squares (empty) on the side
2mm. (as if it were some sort of sampling...). lines and squares
must not escape from the edge of the indicated area.
Thank you. .
Mar
Thank you. .
Mar
