return to make the designer
  • Thread starter Thread starter andre984
andre984
Good morning, everyone!
I'm a mechanical expert. I finished the school only for two years the designer in a company that however did not allow me to accumulate experience. in fact they made me do tasks like warehouses, go to pick up the material from the suppliers and the times I was in front of the pc, alone and without explanation of improvement, complaining even when I was wrong drawings! now that I have done x 3 years the maintenance technician of the softeners and from three I do the storehouse in a car dealer, according to you how can I return to make the designer? Can you give us a chance? ?
Thanks for the attention!
possibility there are always ... being mechanical expert is a great start...other variables ....programs known... geographical area of reference...and above all gain expectations according to "schsi" on this last aspect since you have to fit into a sector and learn a trade, all over northern Italy there are several requests "even without experience" or with minimal experience.
known programs, the classic autocad, a library of the computer qs called top 8.0 (that over time you will have sure changed releases...) and a big passion for computer science that allows me to adapt easily to any program (I run fast...). I'm from the Parma province. gain expectations, of course that if you manage to make "carriera" it is fine the right immediately and then to improve. Do you still recommend the big company or the small company? no because I have already tried to make interviews with big companies of parma...manco recalled!
In my opinion you should first learn a couple of 3d cads, solidworks and inventors that are widespread and relatively easy (listed in order of diffusion) and then try to experience some work in support of studies or companies (up to 5000€ gross per year you do not have to open p.iva). autocad keep him trained that comes back useful snake.
also seeks to "rebuild" the basics of your studies: a "signor" should not only draw lines, but "compel" the work of the designer (e.g. having idea of production technologies, the symbolism of tolerances, the regulations for quotation, thermal treatments, ...)
hi, the only thing I feel about recommending is that if you have so much will then you can get where you want.
Thank you for the moment. In fact what I miss is just the type of experience of "not knowing just pull two lines with the mouse". Unfortunately, not having had the opportunity to be formed in that company, brought me a certain bitterness and the little desire to put me back into play. I found what I found as a job.
But now I want to try again. . .
hi I would advise you regarding learning programs, to see if in your area the province organizes courses, usually funded Phse, inventor and autocad (other specific I have never seen at least in my area) that often end with an internship in some company.
Perhaps to shine as already said some well-made drawing books (where to copy, see examples of pieces put on the table) and perhaps the books of mechanics of the superiors. follow cad3d:-) there are often tips tricks, tips that go beyond books.
quoti
if you can try to do a course in the region, in addition to the additional preparation companies positively evaluate that diploma
