Da Vinci
good evening to all, we consider a cube on which I want to join through the boolean some small spheres. then after using the Boolean union I created a unique solid formed by the cube and the spheres.
But then I would like to put in place the spheres, the small cubes, so I have to lift the spheres and put small cubes. is there a command that "smonta" all by bringing the whole cube and the separate spheres to then add the small cubes? obviously not using the command cancels or the exploding command that just explodes all the surfaces.
Thank you all.
Thank you all.
