reverse
  • Thread starter Thread starter tredm
tredm
Hello.
I was trying to reverse a mesh from me shaped for pure exercise.
My problem is how to approach the reconstruction, that is, how to start, how to extract the theorists of the rays.
I also attached the file.
thanks in advance
Tredm:smile:
Hello.
thanks in advance
Tredm:smile:
as indicated in the discussion linked by marangon, one of the methods is to project curves on the mesh to obtain sections.
from these sections, you rebuild a surface. the deviation of the surface from the mesh will depend on the care with which you prepare such sections and their position.
to better understand the concept, I attach a file with the reverse (untreated) of the mesh.
  • reverse.zip
    reverse.zip
Thanks a lot to both guys, then I take a look at your mariuss file.
excuse me if I repeat, but for the theoreticians of the rays you use some method or always go to the eye through projection of sections?
Thanks again
tredm:wink:
