blue.cat
hello to all, I wanted a council on which of these two tools is more appropriate for a project that I am carrying out within a university workshop.
what I would like to achieve, given the very tight times, is to speed up the drawing work, exploiting views, sections and 3d generated by the software, drawing essentially in the plant.
the design area is extended, it is an entire area around a rail knot; Besides a masterplan I will have to define some design buildings, but the scale will not go beyond 1:100.
I redefine the choice to these two software because they are those used in faculty and are those that I can use with the student license.
the base of departure are drawings in autocad; I used revit 2009 in the past, but I wanted to completely eliminate the 2d passage in autocad-parametric revit. Given the extended scale I didn't want to generate too heavy files, so I thought about autocad architecture, but I never used it.
Can it be useful for you to "push" me on this program to speed up the job? better use autocad and revit?
thank you very much for the advice and apologize if I have been long.
