revit 2012 how to furnish facade continues inside?
  • Thread starter Thread starter andr34
andr34
a simple thing, with revit 2012 I created a somewhat complex window in a wall with a continuous facade system, so mo put the uprights etc.
Now I should retract everything from the axis of the wall because the window is quansi on the inner wire of the wall.I tried in all ways but I did not understand how to do
Andrea
did you try to move it simply?
hi, thanks for the answer, before asking tried everything but the axis of the facade continues does not move, or at least I did not find how to do it, you can move only the climbers by acting on the offsett
Could it be due to some bond I don't see? If I move the facade continues dragging even the walls so I can't move it independently.
if you use the command moves from the edit tab there should be a flag in the options bar that if I don't remember badly is called "divid". ..try that
