rhino nc paths on complex surfaces
  • Thread starter Thread starter pablos
pablos
someone uses rhino nc on path following a complex surface the thalona tool or goes to snaps.
between sup to two tracks and sup from a network of curves does not change
someone can give me some tips
I can't help you, I don't know rhino cnc
typically they are parameters to be set in the various processing strategies, pocket processing rather than flat processing.
if it goes to snaps it may be that cnc control cannot read the infinity of generated points
you should try to increase the processing tolerance so you have less points.
a common problem with dated cnc machines, where numerical control fails to manage xyz axle engines, in short time, so it goes
thanks victorious but the tool runs on board the profile line following the surface,
and propio the surface that not from that softness of continuity
I wanted to see if there was any command to soften the surface without changing the external profile.
ah.. then it is not a problem of rhino nc, rather a problem of simplifying/losing a surface.
I'm sorry, I used rhino years ago, but I don't remember anything.
