rhino
  • Thread starter Thread starter simolrg
simolrg
Hello.
Does anyone know a rhino command that can do this?
I designed a flower in the plant and would like to bring it on an ellipse to make it a bracelet.
Thank you very much.
Simone.
draw the bracelet or to better say do 3d of the bracelet, then to extract the exact air of the surface you will use crea curve uvWith so-generated carriers you create a surface, there positions above the flower
after which you will use Scrolls along the surface
