Falena
I have to shape a surface so as to create a hill, I do not have great constraints but do not find the right command of rhinoceros, can someone help me?
Perhaps, but I do not think I have understood how it works :-s try but without results . I take a look at the help online and I army a littleHave you tried the cage editing under the menu become? That's exactly what you ask!
I have this flat surface and I want to clear it, so I think heightfield nn can help me. Now I try with "drap" and let's see what comes out of itThere are two other commands that can help you to create the surface. then use the cage to change it.
are:
heightfield creating a surface from a bitmap image
drape, create a surface on control points.
I also know little about the cage but I saw it using it is you can do deformations very quickly.
- It's officially gross.I made some quick attempt on a new sheet, I think I eventually agree to make a ball or something like it and then change it with the cage, then cut with a plan the excess ball part. I think it's the fastest and easiest way.
