robot management 2018
  • Thread starter Thread starter alezbg90
alezbg90
Good morning.
I will try to be as clear as possible, I am a mechanical engineer who has recently worked in the office that deals with industrial automation with the help of anthropomorphic robots, as I use inventor 2018, we are looking for a software that starting from the complete island designed in inventor, allows us to do these things:
-realization video simulation robot movement
- encumbrance assessment, process timing,
- generator code/software for handling robots starting from the controls inserted, there is no need to write the code in short. .
all this must be done without having the robot physically in hand, it must be an economic software and easy to learn, it must also manage products other than those for which the software is born for example robotstudio manages well products apt, I don't know if it's good anything else. then another thing, the robot handling software codes are generated in fanuc style language, or c++?? to know if they are editable later for inserting new components, type conveyor belt, grip hand etc...
thanks to patience I wait for answers from a good Samaritan. . .
Good morning.
what you are looking for is a software that allows you to do offline programming of the robot inserted inside a working island.
normally, each robot manufacturer has its own software solution that allows you to do as much as you have written; sin they see only their hardware.
this is not only true for abb, but also for panasonic, fanuc, comau, kuka, etc...
I had your same need a few years ago, i.e. a software that was not related to the hardware solutions of a specific robot manufacturer.
a possible solution is
workspace5 of wat solution (http://www.workspace5.com/),
oppure
robodk della control and robotics laboratory (http://en.etsmtl.ca/unites-de-recherche/coro/accueil?lang=en-ca).
both solutions allow you to download/receive a demonstration version that is worth trying
those few times I had to run a robot we tried two ways: 1) physically with the robot in workshop with self-learning 2) only the pliers designed and withdraw the coordinates in space and then inserted in the matrix of points in the physical software of the robot. something you want should do it freecad with workbench robot. being free try it and see if he does what you say.
robots available are500
210
125
Coke and semi-coke of coal
l
and definitions to create new robots find them qui
