roller bearings
  • Thread starter Thread starter MFT
MFT
Good morning
in the workshop are reviewing a group where are mounted of the rollercoaster micro rods with relative ralletta on which above is engraved the writing nordkapp.
from a research it seems to be a company absorbed years ago by the ina, the problem that that type of bearing so small the ina and skf do not want to know if someone knows some firms that make these micro bearings.
we have already set up to put ina only that the change creates some problems of clutter if you could find the originals would be better.
Mar
Good morning
What measures are we talking about? Did you look at the catalog?
Thank you. I've been looking at misumi now, but nothing to do.
mine is an interior 8/12 x12 and also the ralla is 8/12 those ina start from diameter 10.
I think they're gone.
Mar
Mar
Maybe I didn't understand the type of bearing, but maybe we talk about the hk series skfs for the roller shutter?
http://www.skf.com/skf/productcatalogue/forwarder?newlink=&action=search〈=en&prodid=146111007
http://www.skf.com/skf/productcatalogue/jsp/search/advancedsearchdesignation.jspor do you need an integrated radial+axial unit?
you are that kind only that are great.....however I found them from the nadella of its size now it touches to see only if they have them and delivery times.
Mar
Mar
Nadella? if they don't already have them in stock in Italy, wait and hope.
last week:
50 ralle nadella with hole 31 instead of 30 (at catalog, not special): delivery time 8 weeks except unexpected (practically in September).
customer with machine.
ergo, we've turned them back from k110 to vacuum tempering.
the withdrawal Monday from the treatment and in week another workshop me back rectified and lapped and ready to mount.
thanks meccbell I have seen that it also has iko, I will make to hear to white bearings the times.
Mar
It has always been that the nadella has 2 to 3 months on the supply of material. to me it happened a couple of years ago for eccentric rollers with attached prismatic guides. . However, it seems that in one way or another forcing the system then speed up the times.
what are the best bearings in absolute? Is it true that they are skfs? where can I find a classification according to the value/price ratio?
How do I know more about bearings? Is it enough to read the catalogue?
I care how to choose and how to mount, where is it written?
fag and ina are absorbed into a single company for a long time are as good as skfs? where can I take a general catalogue as for skfs?
atofras, have patience but you opened a lot of posts with the same questions... Wouldn't it be better that you first study a little and then open a post with an exercise and see what to do?
However ina and fag when they were separated made similar or equal products but fag cost less and were a little lower quality. skf cost the right and are of good quality. several emerging companies are making less standard products (special series of stables) and I would say that some are much better than skf. Just think that thk started by making linear guides first standard then special to very low friction, high duration, silent using the system "to cartilage between the turned bodies" and now it has expanded by making ralles and special bearings.
then it is true that many products are made physically by the same companies (Chinese...etc etc.) and are only branded differently.
therefore for the evaluation of the good or bad bearing, use catalog and get made estimate costs.
