roller chain transmission creation
  • Thread starter Thread starter Mec_1802
Mec_1802
Hey, guys.
I wanted a straight from someone if you can help me, in the environment together inside a machine I created a chain transmission consisting of 3 dentate crowns, selected chain size and the position and size of the various crowns and until here everything ok created my transmission, but to this I should add a tendicatena but when I go to add it I place it inside the perimeter of the chain (selecting any option in the positioning table)? . Thank you. !
click on the arrow you see inside the pinion and change the direction of rotation.
dragging him a little here and a little there?
done, he initially puts me the tendicatena between 2 dentate crowns inside the perimeter of the chain, if I drag it between these 2 crowns remains inside if I pass one of the two crowns to bring the tendicatena to the outside we go but it takes behind the chain making him take a ride on himself on the tendicatena so it is not good and even if at that point invert the rotation so remains but the turn!
have you tried within the design accelerator to verify the order of your crowns and tendicatena?? it is not said that if you put the tendicatena for the last one you position where you want.if the chain has to make a certain round and before a crown meets a tendicatena you must respect the order. in the design accelerator modifies the order by moving the tendicatena in the position that should really have why you have the desired turn
also modifying the order of insertion of the crowns and keep me always leave it inside!
also changing the order of insertion of the crowns and keep it always leaves me inside!
That sounds so weird. obvious question but did you tell him for the tendicatena to create a virtual thing with freedom to move in all directions?
thanks to all for the straights....upon. .... let's say that for now I managed to move outside the tendicatena, but not on the side that I wanted....but to go ahead with the project we say that I arranged like this!... but I don't give up and how I have a moment of time I have to be able to put it where I want!! ! !
you can post the file, I would like to try to see if I can do something
update of the last second, while trying to recreate the situation of the transmission to be placed to pietro, changing the order of insertion of the crowns and of the tendicatena following the turn of the chain and "playing" with the sense of rotation as it said davide75 and maybe had already told me someone else, but that I had already done but without result....(do not ask me why...maybe doing things calm and without pressure ! ! ! !
Thank you all again for the tips!!!! !
.........I sell this forum as more useful than the web:finger::finger:! ! ! !
