rolling wheel on top
  • Thread starter Thread starter kertus
kertus
Hello
I need to bind a wheel to rotate on a plane. the plan is part of another set and as such must stand still compared to the wheel motion. I saw the gear connection with the rack and pinion option but this necessarily creates a relative motion (I believe) , instead I only want the wheel motion on a plane that acts as a frame.
How can I solve this?
I hope someone will respond shortly because I have some urgency.
Thank you very much in advance
Hi, dani,
I created two parts: a part with a "fantasm" plan and a part with the wheel. I recalled the two parts. at the first I gave a slider as a constraint, at the second a pin, then I used the gear and obscured the display of the ghost plan. Have I done well or are there easier methods? Thanks :)
