roof with two bonnets
  • Thread starter Thread starter backintime
backintime
Good morning.
Could you tell me the process of creating and sizing a 2-phalt roof?
provided that there is no fixed method... a 2-phalt roof you could do it quickly by drawing a line (which will match your line) and by pressing it with the command "enter me" above the parallelepiped that identifies the construction, or the insole. select the line that autocad has generated with the command imprimes (attention, not the line from you drawn) and with the command moves the port to the height (uplift) from you desired. the bonfires will be created without many other beats. remains only to correct the slope in case the row line was not halfway. also in this case.... selection for edges, and select the edge, or the edges, which you will have to lift
I thank you for answering me but I am interested in getting to know the process using the software autocad architecture and not autocad. Can you help me?
